We are setting up a new Windows MA with new DD-Engine and a new DiskLib. The DDB disk has been configured with recommended 32k block size and the DiskLib volumes with 64k block size.
We have run a new DASH Copy in the SP to create a new dedup baseline from the previous backed up data. And the plan is to make this DASH Copy the new Primary once all data is available.
A standard re-baseline operation, that usually get better dedup ratio with an updated DD-Engine.
The backup data is mostly Hyper-V vm’s.
In this case the Data Written in the old copy was 9TB and the Copy stopped att 18TB in the new MA as it ran out of resources - DiskLib Full.
This was unexpected.
Now we are thinking about doing Move DDB and MountPath but if there is a general Deduplication degration we are not sure if this will work, and if we will run into the same issues again.
Does anyone have a similar experience or knowledge about this issue and a recommendation on how to move forward?
I have done both new baseline and move DDB many times and always with better dedup ratio in the new MA, I was expecting that here as well.
Appreciate feedback,
/Patrik
