I have installed Simpana 11.20 on commvault backup server srvbck (on this machine is also installed media agent which serves backup on Tape library)
Also I have four virtual machines, vsa-agent (which is installed on Citrix virtualization platform) and another media agent htmmediaagent1 which serves backup virtual machines.The backup is located at the htmmediaagent1 server location.
I should add more virtual machines(which are located on different virtualization platforms) for backup
on the Tape library. Then another media agent would be used for backup srvbck… My question is:
Do I need to have another vsa agent installed (on other virtualization) to back up virtual machines to the Tape library?
Do I need to have a separate all agents installed on for each virtualization?
Thank you!
Best regards,
Elizabeta
Best answer by Aplynx
