Hi
Background: Our backups are stored on a Data Domain and the Data Domain replicates itself to a remote site, additionally we've got daily snapshots on the data domain itself to prevent backup data deletion (these snapshots can only be deleted using the sysadmin account).
Because we use Data Domain we are storing our backups without compression or deduplication.
But my question can be the same for the following situation:
Lets assume I've got a media agent, with a data disk (where the disk library is on) attached to it. the building catches fire and I am only able to unplug the data drive. I loose everything expect for the data drive.
If I install a new commcell, can I then import the backups from that data drive somehow?
