Commvault 11.18 (soon to be 11.20). - We are on the cusp of eliminating our secondary backups to tape. The benefit of a secondary copy on tape was the build-in air-gapping (and ability to move it offsite for safe-keeping). We plan to move to creating our secondary copies on disk in a different city. Commvault’s built-in Ransomware protection is no-brainer, but WHAT ABOUT WORM? What are the implications of the WORM storage on space consumption? Is there any scenario in which a WORM-enabled deduplicated secondary copy that is a true copy of the deduplicated primary copy (and with the same retention) would be any LARGER than the primary copy? Presumably, if a 1000 jobs share one block on the secondary storage, that block will not be removed until the last of those 1000 jobs ages out.
Any info is appreciated.
Best answer by Jordan
