I will be very appreciate for help.
I would like to run automatic virtual machine backups tests. Could I ask for an instruction where this functionality will be configured?
Thank you in advance!
Hi
Can you explain what you are trying to achieve please?
What would be the difference between a Production & Test?
Under the same Hypervisor Client, you can create a new Test Backupset, configure Default or more Subclients and finally configure the schedule(s).
Let us know
Sebastien Merluzzi
Hi
By tests of copies, I mean testing the correctness of performed backups. For example: I would like to run a backup restore to the test environment once a month to check if the backup works (virtual machine backups). I would like to do this automatically. If there is such a functionality in the program that it periodically restores the backup, starts it to check it, and then deletes it, please let me know where it is done.
Hi
We do have “Application Validation” in the Command Center which can be used to validate streaming backups of VMware guest virtual machines, including VMs that run applications.
See a link to the feature’s documentation here:
https://documentation.commvault.com/11.24/essential/111292_application_validation_for_vmware_vms.html
Michael
