Commvault tool to determine how much virtual processors and Memory I can use on an existing load using Commcell
  • April 8, 2022
  • 124 views
Existing Commvault Tool
Best answer by Mostafa Amin
Hi @Numismatist,
I think the tool in the following link is helpful
https://store.commvault.com/webconsole/softwarestore/store.do#!/135/662/8487
I recommend to have a look in the store
Aplynx
  • April 8, 2022
Probably could use some more information there. 😉
  • April 8, 2022
Hi Folks,
I would like to ask anyone if  you know of any tool I could use
to determine how much virtual processors and Memory I can use on an existing load using Commcell? Is there one for Commvault?
On a VM with 4 sockets and 4 Virtual processes on a 12 GB of Memory, it is always 90% usage for both CPU and Memory usage
Thanks alot!
  • April 8, 2022
my bad, Aplynx!
Its my first entry here on the community and very happy to exchange information with you all good folks out there!
  • April 10, 2022
Hi @Numismatist,
