Need help in vm periodic replication
  • Jul 5, 2024 5:15 AM UTC
  • 66 views
Forum|alt.badge.img+2
Hi
We have two site main DC and DR site and I want to replicate a vm from DC to DR and we have mediaagent on both site.
What is happening right now is when replication happen it first take backup (dedupe) and then restore from backup to DR site and while restoring process full vm original size and it is choking the bandwidth
Then i take the call with support and he suggested to check the “replicate using secondary copy option” and choose DR mediaagent as storage in secondary copy
Now when replication trigger it first take backup in main DC site then aux copy trigger from DC  to DR site then replication happen but it still restoring the vm from main DC not DR.
Can anyone help here?
Best answer by Deepak Dhiman
It is resolved now, issue was replication from aux copy was going on from source access node. we change it to destination access node then it was working fine
Hello @Deepak Dhiman
Thanks for the great question and details.
I have set this configuration up a few times my self and you need to make sure you have setup the correct copy precedence to be the secondary copy in the restore job.
This setup should work if configured correctly and may need a new support ticket to go over it once more.
Kind regards
Albert Williams
  • Jul 10, 2024 5:32 AM UTC
Please mark this thread as answered.
Kind regards
Albert Williams
