Not able to execute Backup-CVVirtualMachine
  • Sep 22, 2023 4:35 PM UTC
  • 9 replies
  • 150 views
Hi All,
I am trying to run Backup-CVVirtualMachine -Name $vm -ClientName $vcenter
but receive this
I tried to reinstall CVPowershellSDK but it did not help me much, the error stills the same :(
Best answer by Rajiv
Hello @Alexey Tesov
I understand. I would suggest opening a  case with us further to check on this.
Best,
Rajiv Singal
Forum|alt.badge.img+13
@Alexey Tesov
Please follow the below DOC and use the correct Syntax:
https://documentation.commvault.com/11.24/essential/117985_backup_cvvirtualmachine.html
  • Sep 24, 2023 1:41 PM UTC
@Alexey Tesov
Thank you for your answer, but syntax is not an issue in my case
Rajiv
  • Sep 25, 2023 6:54 AM UTC
Hello @Alexey Tesov
Before running the command, are you able to login to your commcell environment using Connect-CVServer cmdlet?
Also, is your proxy/access able to connect with vCenter? Are you able to ping, nslookup, telnet (443) from access node to vCenter?
Best,
Rajiv Singal
  • Sep 25, 2023 7:53 AM UTC
Hello @Alexey Tesov
Best,
Rajiv Singal
Dear @Rajiv,
Yes, my mistake -- I had to provide with more context, sorry
All other aspects are fine, I did Connect-CVServer -- no issues, other commands (like Add-CVVirtualMachine / Get-CVVirtualMachine) run perfectly
If I try to start backup by ID (Backup-CVVirtualMachine -Id $vm_id)  I got the error as well
Rajiv
  • Sep 25, 2023 8:20 AM UTC
Hello @Alexey Tesov
What is the string value are you providing while using -Id or -name switch?
Also, while running the command, can you mention -clientname first and then the other switch -name or -Id?
Best,
Rajiv Singal
  • Sep 25, 2023 1:48 PM UTC
Hello @Alexey Tesov
Best,
Rajiv Singal
Oh Rajiv, I already tried everything possible...
for -Id it is just an int number as a string (“1000”)
I tried direct [string] values as parameters, I tried to pull data from CV for parameters:
$VmDetails = Get-CVVirtualMachine -Name $target
$VmName = (Get-CVclient -id $VmDetails.pseudoClient.clientId).get_Item("clientName")
$VCenter = $VmDetails.client.clientName
Backup-CVVirtualMachine -Name $VmName -ClientName $VCenter
I tried to swap parameters:
Backup-CVVirtualMachine -Name <String> -ClientName <String>
Backup-CVVirtualMachine -ClientName <String> -Name <String>
and nothing works for me
Rajiv
  • Sep 25, 2023 1:52 PM UTC
Hello @Alexey Tesov
Best,
Rajiv Singal
  • Sep 25, 2023 2:06 PM UTC
Hello @Alexey Tesov
Best,
Rajiv Singal
Yes, I will try to do few more attempts tomorrow (with a fresh mind), maybe I missed something; before case opening..
Thank you
Forum|alt.badge.img+2
  • Jun 26, 2024 4:56 PM UTC
Hi was there a solution found for this? I am also attempting to automate some backup/restore jobs using backup-cvvirtualmachine and restore-cvvirtualmachine however I get the same error message.
Seems that the command has a problem finding the client.
PS U:\> Backup-CVVirtualMachine -Name vmname -ClientName clientname
INFO: Get-CVVirtualMachine: no virtual machines found for client [clientname]
INFO: Backup-CVVirtualMachine: virtual machine not found having name [vmname]
