Hello everyone,
About to do a Mine with Commvault deployment, in the documentation it says to download the Mine plug-in from the Commvault store but it is missing:
Does anyone know where to get it?
Hello everyone,
I see this:
I clicked on the hyperlink from this article: https://documentation.commvault.com/2022e/essential/144802_downloading_commvault_plug_in_for_nutanix_mine.html
I’d use the FR24 template, it says this:
So you can just patch the latest feature release/maintenance release on top.
Let me know if your issue is that the files aren’t there and I’ll see what I can do..
Regards
Chris
I see this:
Regards
Chris
Hey Chris,
Thanks for the reply. I have uploaded the .qcow2 image to the Nutanix cluster, but when powering on the VM, I get a Linux server:
The documentation, however, says that:
“The VM console opens and a powershell command executes.”
Kind regards
