does anyone know if there are any plans to support oVirt 4.5.x?
It was released almost a year ago and still the highest supported version is 4.4.x.
Lukasz
Lukasz
Was Red Hat Virtualization not abandoned by Red Hat in favor of OpenShift? I cannot say if oVirt 4.5.x is supported or if it was tested. It might work if there have not been major changes between 4.4.x and 4.5.x.
I thought we mainly supported RHV, not oVirt, despite them being kind of the same product. I know oVirt moved to being kind of a community project now.
When selecting to configure a new hypervisor, only RHV is present.
As far as RHV is concerned, the last version was 4.4.
https://access.redhat.com/support/policy/updates/rhev
With that said, I cannot say if oVirt is being worked on, planned, or if RHV will get deprecated eventually. It is still available in Commvault PR 2024, yet still 4.4, as I believe it refers to RHV.
