VSA proxy installation procedure
  • 6 October 2021
  • 5287 views
Badge +13
Hi all,
my task is to deploy multiple VSA proxies. Since I do this for the first time I can not really imagine all caveats and pitfalls that can be hidden.
The right procedure should be:
  • install Windows or Linux machine (physical or virtual)
  • install VSA module during Commvault package installation (also specify Commserve server during installation)
  • be sure that required ports are open on the newly created VSA proxy
There is a cuple of questions what to do next:
 Any contributions will be much appreciated!
Best answer by Aplynx 6 October 2021, 18:01
Badge +13
  1. Navigate to Client Computers > virtualization_client > Virtual Server.
  2. Right-click VMware and select Properties.
  3. Add the new proxy under proxy\access nodes (depends on version)
Typically CommVault is looking for full admin permissions, but you can customize them here if needed: https://documentation.commvault.com/commvault/v11_sp20/article?p=32134.htm
Badge +8
Always good to follow the Best Practices as well!
