commvault hyperscaletm x advantages and disadvantages
  • June 28, 2021
  • 513 views
Please let me know commvault hyperscale x advantages and disadvantages?
Best answer by Mike Struening
Hey @Buddika !  That’s a pretty broad question :nerd:
What specifically do you want to know?
The advantages are numerous….it’s a scalable, all in one solution, with amazing ransomware protection features, and it’s all Commvault.  You call one support line for hardware or software issues.
I would check out this page which does a far better job at describing its numerous advantages:
https://www.commvault.com/hyperscale
You’ll see that the list of features and advantages just goes on and on, though IO pasted a few of the main points below:
Simple, flexible data protection
  • One solution for all your workloads including containers, virtual, and databases
  • Streamlined installation process that speeds deployment and time to first backup
  • All centrally managed from a single place wherever your data lives via the Commvault Command Center (see below)
Optimized scalability
  • Incremental storage growth up to 5PB of capacity within a single deduplicated storage pool
  • Cost-optimized cloud data mobility to move data to, from, within, and between clouds, including Metallic Cloud Storage Service (MCSS)
  • Data reuse via copy data management that provides instant recovery of VMs, DR testing of replicas directly from the hardware, and live production copies for DevOps and testing
Trusted security and resiliency
  • Ransomware detection with intelligent monitoring detects anomalies and sends alerts
  • Built-in resiliency ensures data availability during multiple hardware failures
  • High performance backup and recovery with automatic load balancing and improved RPO/RTO
