2 different Gridstor point to the same S3 bucket
  • 30 April 2021
  • 118 views
Badge +14
Question 1 :
I have a gridstor  composed of 2 mediaAgents MA1 and MA2
one GDP and 2 partitions.
This gridstor point the a S3 bucket name CVbucket01
I want to create another gridstor with 2 other mediaAgents MA11 MA22
one GDP partitions and 2 partitions.
is it possible to point the the same bucket CVbucket01 or is it mandatory to create another bucket
Question 2 :
When we installed the first gridstor, we selected 2 partitions for DDB. Can I add other media agent and how to increase the partitions ? I know that the limit is 4 nodes per gridstor is it correct ?
Thanks to all for your help
Best answer by Mike Struening RETIRED 3 May 2021, 17:21
@Bloopa , for question 1 are you looking to do failover or round robin gridstor?
For question 2, is this an existing DDB (meaning jobs have been written for a while) or new and unused yet?  Are you seeing any performance issues or limitations?
Want to be sure we understand the end goal which will tailor the answers.
Badge +14
Hi @Mike Struening
Here is a paint diagram, sorry for the quality
Below the answers:
@Bloopa, for question 1 are you looking to do failover or round robin gridstor?
For the actual Gridstor we’re doing round robin and for the second I want also round robin
The DDB is used since 1 month. actually I don’t see any performance issue.
i was just wondering if it was possible to add media agents to the exixsting gridstor if in the installation we select only two partitions :
Thanks !
@Bloopa , you can always add more Media Agents as Data Movers for round robin without needing to add more DDB partitions.
Will that satisfy your potential needs?
@Bloopa wanted to follow up to see if the above answered your concerns.
Thanks!!
