Hello all,
maybe you can help me!?
The following situation at the customer:
Linux system with HANA DB (all HANA specific filesystems connected via NFS)
the customer has one IP for the host and one VIP (+DNS) for HANA (same subnet). The idea is that he can move the HANA system to a stronger host at any time without having to change anything in the HANA configuration (hence NFS).
How do I manage to add the system 2 times in Commvault (1 x under its real host name for OS backups and 1 x as virtual system with the VIP and the HANA DB name (DNS entry for the VIP) for all HANA specific connections? So far Commvault takes sometimes one and sometimes the other IP as primary IP when I create the client and when I want to include the other one I fail. Under Dataprotector this was easy, because there was the possibility to enter a virtual host. So the DB integrations could run over the VIP (and it didn't matter where the DB was running) and the host backup over the host entry
Best regards
Frank
Best answer by Abdullah
