Client connectivity status not ready for MediaAgent
  • 19 April 2021
  • 16052 views
Badge +2
Hi all,
I just installed Unix based Media agent and facing this problem when I check readiness from Commserve Commcell
Client not ready with error 1. Communication failure between Client cvlt and the CommServe. Error returned is:Internal error occurred -5. Please retry the operation.
Media Agent not ready with error 1. MediaAgent is offline. Please check if the MediaAgent is reachable and this product's services are running
Have you ever experienced the same
Best answer by Mahendra Kurniawan 19 April 2021, 11:53
Userlevel 5
Badge +8
Hi Mahendra,
Please confirm with you network team if there are any firewall rules and check what rules for the Commvault firewall are in place.
Please read through this documentation on port requirements for Commvault and confirm they are open
https://documentation.commvault.com/commvault/v11_sp20/article?p=7102_1.htm
https://documentation.commvault.com/commvault/v11_sp20/article?p=8572.htm
Please test the communication on the ports from the commserve to the media agent and then back from the media agent to the commserve.
Check the network connectivity between CommServe and the client computer.
  • Login into client computer.
  • Navigate to /opt/ContentStore/Base
  • Run the following command:
    # ./cvping CommServe_host_nameport_number
On the commserve run cvping from an admin command line.
You can review the cvfwd.log for the communication errors if any.
Badge +15
Hi @Mahendra Kurniawan
Thanks for the question and welcome to the Community.
There’s a few things you can check:
  1. Services are running on the client, MA, etc.
  2. Default communications are over tcp ports 8400-8403 - is there a firewall between the clients? Check CommCell Network Requirements
  3. If there is a firewall and network communications is restricted, perhaps try setting up Network Routes using Direct Connections. Tunnel port 8403 is used by default to route all traffic between client/MA and client/CS - please ensure firewall rules are configured to allow port 8403.
  4. Ensure each client/MA/CS can resolve names of the other clients, check the names used in setup are resolvable by all machines.
Stuart
Badge +2
Hi all,
Thanks for prompt response..
Yes, I have already check those probability and do troubleshooting step as:
  1. Checking if there is no firewall installed in the network.. Commserve have connected to another media agent with same configuration but they can running normally. Also, I have Virtual Server Agent in same host, it’s working fine, no problem with readiness
  1. Do ping and cvping from commserve to Media Agent → they are:
    Ping to port 8400 & 8403 OK
    Ping to port 8401 & 8402 NOK
    I do with other Media agent it give same condition, they don’t have issue with readiness
  2. Client/MA/CS can resolve names of the other clients
  3. Services → compared with normal media agent it’s same
  4. Commvault list, commserve name can’t be fetch from commserve:
    Problematic MA:
    [ General ]
     Version = 11.20.9
     Media Revision = 798
     CommServe Host Name = @@COMMSERVE@@
     CommServe Client Name = @@COMMSERVE@@
     Home Directory = /opt/commvault/Base
     Log Directory = /var/log/commvault/Log_Files
    Normal MA:
    [ General ]
     Version = 11.20.9
     CommServe Host Name = CVLT-MDN-CSPROD
     CommServe Client Name = cvlt-mdn-csprod
Mahe
Badge +15
Thanks for the extra detail, it looks like the MA has failed to register correctly and has the Commserve placeholder instead of the actual name - there is a known issue with this in SP20.
Please apply the latest Maintenance Release and the MA should then register successfully.
Hotfix 2195 is provided in MR12 for SP20 with these details:
HotFix: 2195
Issue: v11 sp20 custom package decoupled install setting CS hostname as @@COMMSERVE@@
Stuart
Badge +2
Hi All,
Thank you for the response, gather many knowledge here
This problem have been resolved, it’s my mistake since I input duplicate VSA and MA IP address in local DNS in windows hosts (Commserve)
Thank you
BR,
Mahe
Badge +15
Hi Mahe
Thanks for the response, I’m glad you got that fixed!
I’ll go ahead and mark your latest update as Best answer.
Stuart
