coomvault upgrade paths?
  • 3 February 2023
  • 225 views
Userlevel 2
Badge +8
Hello everyone -
Im looking for that commvault doc that said you need to upgrade 11.20.* to 11.24 and then to 11.28 etc..
I do see this doc
https://documentation.commvault.com/2022e/essential/2619_platform_release_schedule_and_lifecycles.html
But this just tells me about each release schedule etc.
I want that doc that tells me the upgrade paths for each version.  example - do i need to upgrade to 11.24 to get to 11.28 from 11.20 …?  Does this doc exist?  I dont think you can go straight from 11.20 to latest and greatest?  correct?
BC
Best answer by Brian Bruno 3 February 2023, 22:11
Userlevel 5
Badge +11
Hi @bc1410,
All of our Feature Release updates are Cumulative, so there is no need to install incremental updates in between.  You can update directly from 11.20 to 11.28 if you wish.
We do have this documented here :
https://documentation.commvault.com/2022e/expert/2177_upgrading_commserve_computer.html
That documentation does mention 1 caveat for Commcells that are running 11.13 or earlier, you will first need to go to 11.24 before you can update to 11.28.
However minus that 1 caveat, you can go directly to 11.28 from any supported Commvault Platform Release.
-Brian Bruno
