Hi All,
After updating our Commvault agent on our AIX DB2 Servers to version 11.28.44, the logbackup is not working anymore.
Tried reinstalling the backup agent, but no success. Full backup is running.
Restarted the AIX Server without success.
Simpana status:
[ General ]
Version = 11.28.44
Media Revision = 1081
CommServe Host Name = vmcv001
CommServe Client Name = vmcv001
Home Directory = /opt/commvault/Base
Log Directory = /var/log/commvault/Log_Files
Core Directory = /opt/commvault
Temp Directory = /opt/commvault/Base/Temp
Platform Type = 4
Cvd Port Number = 8400
[ Package ]
1002/CVGxBase = File System Core
1101/CVGxIDA = File System
1207/CVGxDB2 = DB2
[ Physical Machine/Cluster Groups ]
Name = lpas011
- Client Hostname = lpas011
- Job Results Directory = /opt/commvault/iDataAgent/jobResults
Commvault registry for the DB2 agent:
cat /etc/CommVaultRegistry/Galaxy/Instance001/Db2Agent/.properties
.cv.filler
dHOME /opt/commvault/Db2DataAgent
nINSTALL 1
nLOGBACKUPTODISK_SCHEDULERCHANGE 1674033804
sDB2_ARCHIVE_PATH /db2/QRD/log_archive
sDB2_AUDIT_ERROR_PATH /db2/QRD/db2dump
sDB2_RETRIEVE_PATH /db2/QRD/log_retrieve
sDb2ThresholdALFN 2
cvd.log:
19136856 709 01/20 16:25:10 ### TPool [N/A]. Ser# [1] Tot [4], Pend [0], Comp [4], Max Par [3], Avg Work Time [2.29 ms], Avg Wait Time [3.08 ms]
19136856 125b 01/20 16:25:10 --- CCVDSpaceCheck::CleanupIdleEventConnections() - Invoking CleanUp Idle Event Connections.
19136856 125b 01/20 16:25:10 ### periodicallyCleanUpIdleEventConnections() - CleanUpIdleEventConnections started
19136856 135d 01/20 16:25:11 --- CheckAndPruneDb2AuditErrorPath() - Pruning Log Media Offset files in the dir=[/db2/QRD/db2dump ] which have not been accessed for 4 days.
19136856 135d 01/20 16:25:11 --- CheckAndPruneDb2AuditErrorPath() - Failed to open the directory: /db2/QRD/db2dump
19136856 1c5a 01/20 16:25:11 ### PreProcessClientOwnerPeriodicTaskStatus() - Owner association is disabled till next cycle.
19136856 1c5a 01/20 16:25:11 ### UpdateOwnerPeriodic() - Client owner periodic thread is disabled for further processing. Will try again in next run.
Same issue on three of our DB2 servers after upgrade of the CV DB2 agent.
Any ideas are appreciated.
