Failed to check snapshot (replay) details using [StorageCenter/ScReplay
  • 1 December 2022
  • 10 views
Badge +10
Other jobs for this backup copy run -however this subclient errors on backup copy.
The DSM entries are correct in the array manager. The discovery completes - but the mapping to host fails.
I have chosen other nodes in the hyperscale cluster- other vm hosts for the mount process- etc . Other jobs are setup with same config and it works. Not sure what the difference is
Blow away and rebuild subclient?
@Matthew M. Magbee , yeah I’d say one of two ways here:
  • Blow it away, rebuild
  • Call support to see why what should work isn’t
Depends on how fast you need it fixed and how badly you want to know the RCA (no judgement, of course!) 🤓
