Hyperscale connection to tape
  • 2 August 2021
  • 717 views
Badge
I’m asking if i can add HPE Tape library to the Hyperscale appliance by adding HBA adapter then connect the Tape library direct to to it
Best answer by Justin Wolf 2 August 2021, 16:43
Badge +14
Hello Eslam,
What Hyperscale Nodes do you have? 1.5 / X? also are they Reference Architecture?
-In the field previously, I have deployed ref-arch HS nodes (1.5 and X) with FC HBA’s connected to Tape Drives without issue.
Michael
Userlevel 2
Badge +3
@Eslam Salah
Yes tape drives/Libraries are fully supported with HyperScale with both FC and SAS connections. Tape drivers are included within the HyperScale and HyperScale X images so in most cases drivers will not need to be installed. See https://documentation.commvault.com/11.24/expert/105348_tape_library_support.html for more details.
Badge +3
Hello @Justin Wolf ! Relate to this post.
I have Hyperscale Nodes 1.5 with Reference Architecture and i would like to connect my librabry within the hyperscale. Do i need to install 1 HBA card on each server or just install only 1 HBA card among these hyperscale servers to backup full data on tape?
To clarify my question... Do I need to install one HBA card per cluster to make a full backup of data on tape or do I need to install one card on each server hyperscale. What is the best practice?
Userlevel 2
Badge +4
Hello @commvault11
Ideally you would use iSCSI to circumvent the need for HBAs.
If you need to use SFP or similar, you can installed 1 HBA in one node and use that as the datamover, but you lose failover. Generally best practice is to have 3 nodes each with an HBA for failover datamovers to tape and load balance.
Badge +3
Thank you very much!
Badge +3
We have a 3 node HSX cluster, FC connected to write to an HPE MSL6480 which requires the RHEL Path Failover driver to be installed. The comment above about ISCSI seems odd to me.
