I’m asking if i can add HPE Tape library to the Hyperscale appliance by adding HBA adapter then connect the Tape library direct to to it
Best answer by Justin Wolf
Yes tape drives/Libraries are fully supported with HyperScale with both FC and SAS connections. Tape drivers are included within the HyperScale and HyperScale X images so in most cases drivers will not need to be installed. See https://documentation.commvault.com/11.24/expert/105348_tape_library_support.html for more details.
