I have a commvault client that appears to be backing up the HANA database via the filesystem subclient, and I set the nFilterApplicationFiles setting and a full ran over the weekend and there was no change in the size and files backed up, and looking at the content of the backup, it appears there’s > 2 TB of data backed up in the fileystem subclient that’s in the /hana/shared/[db] path. I was under the impression that nFilterApplicationFiles would prevent that… but the “database discovered” is located in the pseudoclient, not the SAP for HANA agent associated to the server level commvault client….
Questions:
- Does the nFilterApplicationFiles setting “work like it should” by not backing up the HANA database when the HANA pseudoclient is used as the backup method, and backups are “pushed” to commvault via the SAP/HANA side (using backint?).
- Are there other settings/configs to make it work? Like something I would have to do in the “SAP for HANA” subclient? I coudl manually add in filesystem subclient level “ignore filters” of the DB paths, but I was hoping nFilterApplicationFiles would handle it dynamically
Best answer by Sunil
