Restore index cache failed
  • 18 February 2022
  • 1582 views
Userlevel 2
Badge +8
i need a help :(
primary : vtl ( media agent : senvtl01
second copy : aws ( media agent : test200
i try aux copy( senvtl -> aws) result: OK
i try restor from aws of test200
but, no index cache label was found in the specified location. check failed.
Best answer by Orazan 18 February 2022, 10:05
Badge +15
Chris,
Good morning.  Quite often when the index label can not be found, the resolution is simply to go to the properties of the MediaAgent and then the Catalog tab to change the Index Cache location.  You can move it to another location on the same MediaAgent, even to another folder on the same volume.  This will rebuild the label.   If you wish to move it back after, that is also an option.
Try this first if you can and update me as to if it resolved the issue.
Userlevel 2
Badge +8
Thank you for your advise.
i solved it. 😃
