send event monitor to Solarwind
  • 26 October 2022
  • 189 views
Userlevel 1
Badge +6
I need to send events from the commvault to SolarWinds. The SolarWinds guy want to do it from Microsoft event viewer, how can i send commvault event and alert to Microsoft event viewer.
Best answer by Jean-Paul 27 October 2022, 08:39
Userlevel 5
Badge +14
Hello @Jean-Paul
It may be possible through REST API’s. If SolarWinds can leverage REST API, you can refer to the below documentation on Commvault API’s.
REST API Overview - https://documentation.commvault.com/11.26/essential/45540_rest_api_overview.html
Thank you,
Collin
Userlevel 1
Badge +6
Thank you , I found this Article and it’s works
https://documentation.commvault.com/2022e/expert/5394_setting_up_windows_event_viewer_alert_notifications.html
Userlevel 5
Badge +14
@Jean-Paul  Glad to hear you were able to find a solution.
Thank you,
Collin
