Automated backup/restore testing of a MSSQL Database
  • 3 February 2021
  • 3211 views
Badge +1
I currently have a workflow setup to do a weekly backup/restore of some Windows filesystems, which works great.  Is it possible to do the same thing with a Workflow and backup/restore a single Microsoft SQL database (out of place)?
I cloned the workflow I have for the Windows files and was trying to modify it for MSSQL.  It looks like I can change the agent type to MSSQL and even set an instance name.  However, I’m not sure how to define a specific database.  As I’m typing, I just thought of maybe a possible solution?  Maybe I need to create a new backup set with the database(s) I want to test?
Any recommendations on the best way to automate these backups/restores?
Badge +10
Hi! I’ve been dealing with something similar recently.
Here, my example of SQL backup/restore workflow (still in early stages!).
Phases: Backup → Out-of-Place Restore → CHECKDB → Email
Backup phase: in order to backup specific db (or more of them), you simply create a user defined subclient and put db in it.
Restore phase: this one is a bit trickier. The easiest way is to use ‘Save As Script’ xml exports ‘Execute’ activity. Use your Java GUI: <client> → <SQL Server> → <Instance> → All Tasks → Browse and Restore. Select ‘Advanced Restore’, dest. client, instance... and click ‘Save As Script’.
Use ‘Execute’ workflow activity (QCommands → Operation → ‘Execute’) and put xml content from previous step into inputXml.
Finally, replace values (client, instance, db, path...) in xml with user inputs.
Example:
<clientName>yoursqlserver</clientName>
change to
<clientName>xpath:{/workflow/inputs/SQLClient/clientName}</clientName>
That’s it!
There is also a workflow called ‘SQL-Documentum Restore’. You can download it from Commvault Store and modify it to your needs.
Badge +13
Such a workflow would be handy for automating "refresfes". (I asked the same question on the old forum)
Badge +13
@Chris M would you be able to share that workflow for Windows that you use?
BR
Henke
Badge +1
Example:
change to
That’s it!
Thank you so much for your help on this.  I’ve got this setup and it’s working well.  The only thing I need to add is for it to cleanup the restored database after it’s successful.  Other than that, it works great!
