We’re a Service Provider and want to automate reoccurring tasks using Python, so we can integrate these in our business processes. (examples: creating new schedule policy, creating new storage pool, create scheduled report)
As I’m new to Python it would be really handy to have some way of converting a Commvault action to a finished Python script/command, similar to how you can see certain API equivalents or save certain actions as a script from within the Java Console.
Is that possible or some other way to get the Python command equivalent without having to manually put it together?
I’m aware of the info on the documentation online and GitHub, but it would be great to have more examples than the ones on the documentation site so they can be used as a guideline for non-Python pros. For example for each option a quick example, as it is done with the qcommands.
Best answer by christopherlecky
