Delete VMDisk Filter doesnt work
  • 7 May 2024
  • 10 views
Badge +1
does anyone know how to delete Disk Filters on a Hyper-V Subclient via qcommand?
Add works, modify works but delete doestn do anything to the filters.
Im Using this XML: documentation.commvault.com/2023e/expert/files/products/vs_vmware/command_line_xml/update_disk_filters_template.xml
And the job is running (any spelling error results in pending jobs) but nothing happens to the filters.
XML Parameters for Microsoft Hyper-V Backup Set Configuration (commvault.com)
In the xml i’m just swapping “ADD” to “DELETE” and this entry should have been removed.
Thanks for help and regards
Jacob
Userlevel 1
Badge +3
Hi @Jacob.sp
The syntax for the xml looks fine (DELETE), could you please provide the details for the diskfilter added in subclient properties that you want to delete and the value being specified in the below area?
<filters filter="" filterType="" vmGuid=""/>
Keshika Bisht
