JSON Response
  • 14 April 2023
  • 87 views
Badge +1
I am able to successfully query the rest API and the xml data looks good but when I use ‘Accept: application/json’ the data is not formatted correctly. Is this a known issue? I tested this feature in both python and curl.
Hi @J-Rod,
Some API requests do not yet support JSON, as such I’d unfortunately say its a known issue. Which API are you calling?
Badge +1
Get Storage Pool
http://WebConsoleHostName/webconsole/api/StoragePool
Get Storage Pool Details
http://WebConsoleHostName/webconsole/api/StoragePool/{{StoragePoolId}}
Get DDB Store Info
http://WebConsoleHostName/webconsole/api/DDBInformation/{{storeID}}
Userlevel 5
Badge +16
@Damian Andre is correct, xml is supported everywhere. I personally prefer working with json, so I just convert xml responses to json.
