Rename a clientname via API
  • August 25, 2021
  • 418 views
Juergen
Explorer
I want to rename a client via API, but it doesn’t want to work, I use following:
http://testcommcell.xxx.com:81/SearchSvc/CVWebService.svc/Client/<ClientID>
XML file looks like :
<association>
    <entity>
      <clientName> "<cname>" </clientName>
    </entity>
  </association>
  <clientProperties>
      <clientEntity>
        <clientName> "<cname>_decom_07.10.2021" </clientName>
      </clientEntity>
  </clientProperties>
</App_SetClientPropertiesRequest>
error : <Api_GenericResp errorMessage="Failed to set Client properties." errorCode="1" />
Environment: V11SP20.55
Any idea what I do wrong?
regards Juergen
Best answer by Kcsaby
Juergen
Please review the following doc link - there is an example that you can use to change the client’s name
https://documentation.commvault.com/11.24/expert/7051_changing_client_computer_name_using_command_line_interface.html
this is done on a command line but the XML file that is there can be used elsewhere as well as a base of what you wish to do.
qoperation execute -af update_client_name_template.xml -entity/clientName 'old_clientname' -client/clientEntity/clientName 'old_clientname' -entity/newName 'new_clientname'
You can also edit the update_client_name_template.xml for your needs with out all the command line options shown
Hey @Juergen , thanks for the post!
My initial suspicion is that the cname variable needs to be outside of the quotes, though the generic error message is, well….generic.
I’ll add in some of our folks who are better skilled at our API calls to help.
Juergen
Explorer
  • August 25, 2021
Hi @Mike Struening , thanks for answer.
I think that was bad sample for placeholder, it looks so:
<clientName> "FQDN" </clientName>
and
<clientName> "FQDN_decom_07.10.2021" </clientName>
rename from FQDN  to FQDN_decom_07.10.2021
I hope that explains better
Juergen
  • August 25, 2021
Juergen
Juergen
Explorer
  • August 26, 2021
Hello @Kcsaby,
Now I got it working! Thank You.
A second problem was the quotes at the name now it looks:
<App_SetClientPropertiesRequest>
  <association>
    <entity>
        <clientName>FQDN</clientName>
        <newName>FQDN_decom_07.10.2021</newName>
    </entity>
  </association>
  <clientProperties>
    <client>
      <clientEntity>
      </clientEntity>
    </client>
  </clientProperties>
Juergen
  • August 26, 2021
Glad that worked out for you and I was able to help you.
Ken
