REST API Endpoint for Health Status
  • April 26, 2021
  • 343 views
Forum|alt.badge.img+2
I tried to get some Information similar to the Health Status Dashboard by Rest API.
I only need the overall Results and not all details.
Is there any endpoint which i can use to get it?
Best answer by MFasulo
Bjoern: I’ve been using this report, which is rolled up via “topic” grouping instead of severity.
https://commserve/webconsole/survey/reports/health.jsp
The REST API for that report is:
https://commserve/webconsole/api/cr/reportsplusengine/datasets/METRICS_DEFAULT/data?livefeed=true&offset=0&dateFormat=milliseconds&limit=-1&parameter.param1=-1&priority=normal&operation=METRICS_EXECUTE_SP&nullValue=&parameter.spName=RptHealthCardSummary&syscol=false
It provides number severity and timestamps, along with multi-commcell enabled, so I can monitor my entire estate that way
MFasulo
  • April 26, 2021
