Trigger external script on failing Jobs
  • May 3, 2021
  • 374 views
Juergen
Explorer
I am looking for a solution which can trigger a script outside from Commvault when ever a backup job is failing. The script needs only give over the failing JOBID.
Plan is to automate a quick analyze of the failure and trigger the right team to fix the issue without manual invention.
thanks in advance for your suggestions.
regards Jürgen
Best answer by Blaine Williams
Hi Juergen,
You can use the alerts and notifications on failed jobs to trigger a command line to run scripts if you require.
Alerts : https://documentation.commvault.com/commvault/v11/article?p=5196.htm
Command Line notification https://documentation.commvault.com/commvault/v11/article?p=5401.htm
However if you just want to notify the teams when there is a failure with details just use CV to do it. You can then configure separate team responsibilities between alerts and have it notify them.
Creating an Alert : https://documentation.commvault.com/commvault/v11/article?p=5203.htm
There is also a predefined alert already created you can copy and modify.
https://documentation.commvault.com/commvault/v11/article?p=5199.htm#o131659
Backup job failed
Job Management / Data Protection
This alert notifies the user when a backup job fails to complete, fails to start or is stopped by the system
Forum|alt.badge.img+8
Hi Juergen,
Backup job failed
Juergen
Explorer
  • May 4, 2021
Hi Blaine,
thanks, that was exactly what I am looking for, sometimes you see the wood not because of the many trees (German proverb) :sweat_smile:
regards Jürgen
Our version is “Not seeing the forest for the trees” :joy:
You Welcome Juergen.
Our version is “Not seeing the wood for the trees”
