HSX OS upgrade from 7.9 to 8.9 with sp32
  • 26 February 2024
  • 51 views
Badge +1
we are trying to do OS upgrade the HSX from the existing 7.9 to 8.9 to be able to add additional new nodes (HSX ISO 3.2312)
we tried to upgrade the OS using the Command center and CLI both showing upgrade completes successfully however the OS version is still 7.9
i used the below reference for the OS upgrade operation.
https://documentation.commvault.com/2024/expert/installing_operating_system_updates_on_hyperscale_x_reference_architecture.html
Badge +8
Hi @Nawras Haddadeen
Upgrade from RHEL to Rocky has a different procedure. I would suggest to connect with the Account Team who can work internally on this.
