I want to know if there is a procedure when we want to migrate an existing hyperscale X to an existing commserve?
Regards
Hi @nhaing
If you are looking to use HSX on another CS, then you need to clean the nodes i.e. delete/age data, delete StoragePool and MA.
Once done, re-image the nodes and register on new CS.
Hello @R Anwar,
thanks for your reply, i want to know what you mean exactly to “re-image the nodes and register on new CS. “.
Is there any documentation for the case?
Regards
