We are running some pre-DR tests and workflows and I have come across an issue with VMWare VM restores (Windows) to Azure. Basically, the Azure agent does not get installed. The server can be reached through RDP, but other extensions that require the Azure agent, won’t work.
I worked with Microsoft and they showed me how to install the agent, both online and offline. However, looking through the documentation, Converting to Azure Resource Manager (metallic.io), I see a mention of installing Hyper-V drivers for Linux, but nothing for Windows machines.
Is this normal behavior?
Thank you!
Best answer by akirby
