Hi
On endpoint backup plan there is option “RPO” under backup frequency is every 4 hrs. this every 4 hrs. is full backup, incremental or differential, and is there any way we can confirm the backup running every 4 hrs. is full, incr. or diff.
Hi
Best answer by Ryan Carr
Hi Aju
The first job will be as full and subsequent jobs appear to be incremental
you can view this via the laptop section. Select a laptop and view jobs to view the history
In the next window use the columns feature and select Backup type. this will show you the job history and backup type
Let me know if this helps
Ryan
