Error code: [19:2586]
Description: Another backup job [52212350] is running for client, iDataAgent [Oracle RAC], Backup Set [defaultBackupSet], Subclient [default].
Source: cms01101c1us07, Process: JobManager
@Raj L
There is a another job running for the same sub-client. You can check the same under Jobs>Active jobs.
Please wait till the jobs gets completed and then start the new one.
Most likely job is triggered twice for the same scope, so the second one is failed/skipped or the new one is triggered before previous was completed.
