All job activity in commcell Activity control always turn off automatically
  • 6 February 2023
  • 7 replies
  • 130 views
Badge +1
Hello All,
i am looking to a solution for my commcell issue which is:
All job activity in commcell Activity control always turn off automatically.
so all the backup jobs not work.
Badge +17
Please check the Audit Trail report to see if this change is being logged.
You can set the Playback Level to High and enter the search string: Update CommCell properties
You should see a record like this:
Then you know which user is being used to perform the activity.
Question still is, how is this performed.. Thinking about how to identify this 🤔
Badge +17
Can you also check if a DR backup is performed around the time the activity is disabled?
If so you might have a Database corruption, when the Disaster Recovery Backup detects this the CommServe job activities are disabled automatically.
Badge +1
Dear @Jos Meijer thanks for your answer, yes you are correct i see a problem with SQL as follow image:
so how can i solve this database issue
Badge +17
Good dat the reason has been identified 👍
To be honest I would contact support, they will get you back on track asap.
Analyzing the issue through this forum thread will unnecessarily delay your solution.
Badge +1
@Jos Meijer thanks alot
Badge
Hello All
nearly,I had the same problem,how to solve this problem?
Badge +8
@sc.zhao
In CommserveDR.log, if you see consistency errors in the DBs, please raise a case with support for further analysis and provide the right POA to solve this problem.
Example:
