Hi @Michal128
Thank you for reaching out.
I do believe both would be supported as both would be seen as a disk library in Commvault.
I will get this verified and update the document accordingly.
Hello Community,
I checked the possibility for both solutions. In my option Storage Data Box Disk is completely unuseful. Few thinks:
- Storage is divided on 5 separated disks.
- Payment started from beginning when usage that solution lunched.
- Supported OS which can use that solution is only until Windows Server 2016.
So from my used study please use only Azure data box, or Azure Data Box Heavy.
Michal
Hello @Michal128 ,
Any feedback about Azure Data Box? Did you used the service?
I try to understand how you are going to “see” the Disk Library in the Data box, in order to proceed with aux copy.
Nikos
Hello NIkos.
The Azure Data Box is visible from the Commvault Commcell as NAS storage. From my site I see that only useful is Azure Data Box and Azure Data Box Heavy. We ordered the Azure data Disks, but this feature is not useful completely, because that hardware is delivered are separated disks, so if You have 5 TB of data only maybe that solution can be use, but for another only Azure Data Box or Heavy type.
Michal
