Backup VM machine with 2 separated datastores
  • July 7, 2023
  • 137 views
We have a big VM machine that uses 2 separated Netapp datastores as its storages. I wonder if intelliSnap could work on this situation? If not, which method should we do to backup this VM machine?
Thank you.
Best answer by asancheti
Hello @TD89 ,
With intellisnap ,
 it will first create the snapshot on the VM and then create the hardware snapshot for both the datastore.
There will be only one snapshot on the VM.
  • July 8, 2023
IntelliSnap backup should work with VM spread across multiple datasores.
  • July 8, 2023
Hi @asancheti,
Thank you for the response. I still don’t quite get it. So, if I have a VM uses both NetApp-datastore-1 and NetApp-datastore-2. When I use the intelliSnap on both of these 2 Datastores, It would capture the snapshot of this VM 2 times?
  • July 9, 2023
Hello @TD89 ,
With intellisnap ,
  • July 9, 2023
Hi @asancheti
Thank you for the reply.
I have another silly question, and I hope you don’t mind.
For example, the C and D drive of that VM use the Netapp-Datastore#1, and the E drive uses Netapp-Datastore#2. As I enable intelliSnap backup on both Netapp-Datastore#1 and Netapp-Datastore#2, when the backups kick in, the Netapp-Datastore#1 will create the snapshot for the VM first, then it will create snapshot for the hardware which are the drives. And for the Netapp-Datastore#2 it will only create a snapshot of a E Drive right?
