BD oracle grid
  • December 22, 2022
  • 78 views
FeRox
Explorer
Dear Sirs.
Please your valuable help with the following question:
Are ASM grid databases in oracle supported and how can they be backed up by commvault?
Thanks 😁
Best answer by Gowri Shankar
Good day @FeRox
Yes, Commvault agent leverages RMAN to protect the database files residing on ASM
Please refer the documentation -. https://documentation.commvault.com/2022e/expert/115797_oracle_agent_windows.html
Forum|alt.badge.img+13
  • December 22, 2022
Good day @FeRox
FeRox
Explorer
  • December 22, 2022
Thank you very much.
@Gowri Shankar  You are the best. 🙌
By the way, there is no problem that the database is in STARTED mode.
