I am trying to NAS backup with NDMP agent but when i am running incr backup its taking to long or de backup faile. The volume have more then 14M small files.
What is best practice to backup it? Intellisnap maybe?
Hi
That is correct, we would recommend you use IntelliSnap.
Sebastien
CIFS share and File system agent in my experience will give you the best performance.
And what is about iops and ms performance, because i tested out file scan phase my iops went to 8k instead of 800 and ms to 30 instead of 3
