Block Level Backup Options-Optimize for Table Level Restore.
  • February 23, 2023
  • 161 views
FeRox
Explorer
Dear friends, I have another question, why when the block level is activated, the backups are executed by a single stream, and this is already a problem because it degrades the speed of the backups
Best answer by Scott Reynolds
Hello @FeRox
Correct I responded on the other thread.
Yes it would apply to all versions.Single Stream when enabled.
Believe the limitations here is the VSS writer
https://learn.microsoft.com/en-us/sql/relational-databases/backup-restore/sql-server-vss-writer-backup-guide?view=sql-server-ver16
Forum|alt.badge.img+16
Hi @FeRox
Which agent are you using for block level backups ?
Gowri Shankar
FeRox
Explorer
  • February 23, 2023
Hi @Gowri Shankar I am using SQL Server
Hello @FeRox
