Hi!
According :
https://documentation.commvault.com/2023e/expert/22355_configuring_sap_hana_system_replication.html
“The order must be the primary node and the secondary nodes.”
How to change node order from webconsole? I can select nodes but not set up the order :
From java console node order can be switched using arrows :
Thanks.
Best answer by Sunil
