CLI command to list all clients and its sub clients in CommServe.
  • November 8, 2023
  • 319 views
Please help me with the CLI command that list all clients and its sub clients in CommServe and save the output to .csv/.txt file.
SparshGupta
  • November 9, 2023
Hi @Biren
You can explore the available qscripts at this link: List of Available QScripts.
Feel free to write a brief script tailored to your needs using the provided resources:
Sparsh
  • November 9, 2023
Hi Sparsh,
Thank you for your reply.
I am aware of this scripts. In the documents there is not much information. I have list of all Clients but i need a way to input that file and use some looping to get sub-clients info for all those clients. I am not expert in scripting so if someone have the script knowledge then please share your commands/script.
@Biren
Also on the existing script you can pass the switch for input.
-i ‘C:\jobstofail.txt’ like this.
  • November 15, 2023
@Biren
Please try using the API call and check if this meets your requirement.
https://api.commvault.com/#acbfba91-32e1-493e-a607-b20eba72fb84
https://api.commvault.com/#e03e735c-2000-42dc-8680-41894faa9ce3
Thank you Navneet. I will take a look at API call but the thing is my employer don’t want to configure/install any additional components so i need to stick with using scripts only.
