Client registration failing with authcode error - authcode is fine.
  • June 6, 2022
  • 7 replies
  • 1130 views
christopherlecky
Challenger
Forum|alt.badge.img+16
I am registering a client using the following process
https://documentation.commvault.com/11.24/expert/2121_registering_client_using_command_line.html
I get the following error codes:
<clientError ErrorCode="67109714" ErrorString="Given authcode is not valid. Please provide the correct authcode to proceed with registration." errorLevel="2"/>
<SimError ErrorCode="4294967295" ErrorString="Given authcode is not valid. Please provide the correct authcode to proceed with registration." errorLevel="2"/>
I have used this authcode and I know it to be valid, what am I missing here?
Best answer by Orazan
I checked the case that was created and it was closed with the following resolution:
“The auth code in the XML had a typo. Even though we have been using this package for years, we always used it as a silent install and passed the correct Auth code when calling the installer.
Because of the other issues we were having we switched from silent install to interactive install without noticing that the code in the XML was off by one letter. Once the other issues (firewall, packages and unix group) were resolved the install would have worked if not for the typo.”
It appears this issue is resolved.
Hi @christopherlecky
Sometimes if there’s a communication issue during registration, you can see this error. Can you check SimCallWrapper.log on the client for any communication errors or attach the log here and I can have a look.
christopherlecky
Challenger
Hi Matt,
I will send additional details in a little bit.
Thanks, for following up.
christopherlecky
Challenger
I have a ticket ID associated with this issue:
if someone can take a look.
220606-358
The CVinstall.log shows the dirty details.
@christopherlecky , can you double check that case number?
christopherlecky
Challenger
It’s correct but it’s not under my name.
initials for the user is cl
Oh, ok, that matches!
Forum|alt.badge.img+18
  • July 2, 2022
