CommServe Failover Using Disaster Recovery (DR) Backups
  • September 23, 2021
  • 396 views
Can the CommServe installation created during Testing CommServe Failover Using Disaster Recovery (DR) Backups procedure be maintained after the test? Do I need to turn off the server or to shutdown Commvault Services?
Best answer by JBuratti
Hi Eduardo,
After you performed all the steps for a test failover using a DR backup as per the link below, you can do whatever you please with the test DR server.  As long as the database was restored in the “Maintenance/Staging” mode and any test failover group you created was reverted, then this server would be “disconnected” from the rest of the environment.
https://documentation.commvault.com/commvault/v11/article?p=43536.htm
You can certainly keep the services on and use it as a testing server or keep them in a stopped state.
You can also use this a a cold standby DR server in the event your production server ever failed.
Let us know if you have any follow up questions.
 - Joe
Hi Eduardo,
 - Joe
