Hello Community,
Can we implement Commvault AirGap in Cloud Commserve ( CS , clients , MA are cloud instances with cloud S3 library).
If yes , any reference how to achieve it.
Regards, Mohit
View originalHello Community,
Regards, Mohit
View originalThanks,
Is this AirGap ?
I guess this is Cloud Power Management , powering off media servers is useful in terms of cost saving but doesnt provides Air Gap for data stored in Cloud Storage Library( S3 or Blob).
In case a second region is not an option, then applying S3 object lock/WORM in the present region is also a possibility which reduces the effects of a possible ransomware on your backup data.
