Commvault browse and copy index location
  • June 18, 2023
  • 134 views
On all of our storage plans we have an auxiliary copy that is uploaded to an S3 bucket, we have been doing some DR scenario testing recently which has involved  failing over to our CS server in AWS.
How does the indexing work when doing a browse and restore operation? We have no index server in AWS however for the restores i’ve tested (when using the S3 data copies) it appears to be running a restore job & completing successfully, is the indexes stored in the s3 buckets?
Best answer by Sebastien Merluzzi
@KevinDodd ,
You can select List Media during the Browse and select the second option:
HI @KevinDodd ,
During the Browse, the indexes are being copied to the Media Agent you are using.
Sebastien Merluzzi
  • June 19, 2023
HI @KevinDodd ,
Sebastien Merluzzi
Thanks Sebastien, can I ask where the indexes are copied from?
@KevinDodd ,
  • June 19, 2023
@KevinDodd ,
Just what I was after - thank you! looks as though the index data is stored on the storage location, in my case the S3 bucket.
Thanks again!
