Hi Team,
Please help me for the examation
Hello
Thank you for coming to the forums. Could you please elaborate a bit on what you require?
Thank you,
Collin
Hi
I would recommend to create a Virtual Lab and install the product, then thoroughly test it before attempting the exam.
You could download the install binaries from https://support.commvault.com/ESD?fv=11.0
Once installed, it will have a test license for 90 days.
Documentation is also a good tool to learn about the difference aspects of the product = https://documentation.commvault.com/
Then once you have read about a particular feature you will be able to put it into practice in the lab.
