We were thinking to try out the Commvault containers images in combination with Tanzu, but we would like to provision by making use of an authcode instead of username and password. Can't really find if this is possible and which attributes I should use to populate the authcode.
Page 1 / 1
Hi Onno,
Auth code support is currently not there.
For us it would be company/commcell auth code. I personally do not see a use-case to use API tokens to add client objects. I already raised the CMR.
