Commvault Lincense SKU
  • September 14, 2023
  • 945 views
I'd like to ask you a question about commvault license sku.
I want to know the difference between CV-DR-VM and CV-BKRC-VM10 SKU.
No CV-DR-VM required for CV-BKRC-VM10 purchase?
Do I need to purchase CV-DR-VM to use VMware Replication (LIVESYNC) capabilities? Or can I also use the feature with CV-BKRC-VM10?
Best answer by Sebastien Merluzzi
Hi @KIM TH ,
The CV-DR-VM10 SKU does not grant any entitlement to protect virtual machines; it only grants Live Sync capabilities.
The CV-BKRC-VM10 SKU contains backup entitlements but no DR capabilities.
The best is to speak to your Account Manager so he can check and confirm what you need.
Sebastien
Hi @KIM TH ,
Sebastien
Thank you for your reply.
